Hi there. I am just finsihing up some tune up work on a 1976 evinrude 2hp outboard i.e. cleaned the carb, replaced the inlet valve, needle, float and gaskets and then tested it in the water. It ran great with some adjustments to both the high and low speed needle valves...problem...when I got home I noticed that fuel was leaking from the bottom of the carb, and when I turned the high speed needle all the way in, it stopped
I did not work on the needles or the packing, etc...maybe I should have? Could th eplastic wahser have eroded after all these years. Apparently this motor had not run for 20 years
Sharky
Sharky
