Finally i have my TXP installed. A quick test run revealed that top speed at wot is a about 45knots at 5100rpm, this is with the engine trimmed out of the scale of the trim gauge. It's quite obvious that the engine needs to be raised a bit. The AV plate is about 1cm above the bottom. I'm installing a water pr. gauge. Can somebody give an educated guess how much i should raise the engine to start with?
pic of my boat
pic of my boat
