I have had a slight rattle in the drive when turning sharp or at high trim angles on my Bravo III Merc. So, I replaced the gimble bearing with a new sierra bearing, with everthing done by the book. Took the boat back out, and at first the problem was fixed, but the more I ran, the more the rattle came back to the point that it is now actually worse than before.
While working to replace the bearing, I slid the old bearing onto the drive shaft and twisted the bearing back and forth noticing slight movement. (about 1/16" at most) I then took the new bearing out and did the same test, with the same results. You can't really see this play by just moving the bearing in your hands. It has to be slid onto the drive shaft or alignment tool to really see the play.
Is this normal? Or did I buy a crap bearing? I'm currently planning to order new u joints, as this is the only next step I know. But, my u joints looks and feel perfect. No play in any direction. Only clean grease comes out when greasing them, no water or rust color. No water in my bellows either.
