I removed the hose from the lower crank case bleed valve and I get a few drops of white liquid. It smells like gas and soaks into a rag like gas, and could be the remants of the white grease I used to install the rod bearings mixed with fuel. It could also be water mixed with 2 cycle fuel.
Question: If it is water, can it be from a leaking inner water jacket cover or baffle plate? Can water travel through the combustion chamber and past the rings? Or is it likely I have a bad lower crank seal?
