Re: 95 GTS--Just quit running.
Again I know I had two in the shop, got one out today (bad coil).
The safety switch on that ski is a simple contact one. If it not making contact it will not turn over, all that will happen if you press the start button is it will send power to the mpem, the gages will work and the trim if it has one (for 30-35secs), if you press the start button 2-3 times it will beep (to let you know the lanyard is not on).
He says it cranks so it is not the switch.
There are I few things it could be I would first check for spark.
If you really would like to check the switch jump the two wires leading to the switch, simple.
