I need some trouble shooting help. I had not run my boat in a month or so but it started up fine and we went out on the lake. It was running fine but when I tried to slow down the shifting linkage seemed to be stuck. I finally got it slowed stopped. I checked to be sure that I could go from neutral to in gear with the engine off and it seemed to be fine. But of course now I have a new problem, the engine will not idle. It starts great and runs at high rpms but if you shift it into neutral it dies. I have changed the plugs and wires but still have the problem. As a test, I set the idle to be at about 2500 rpms and it will idle but really rough. At this point, I could put it in gear but I have no power at the high end.
I figure that I probably have a couple of problems. I want to try to get the idle to work and go from there.
