I am thinking of a new setup for my two battery system on my 17' whaler w/ 90hp johnson. Thinking about this due to charging problems (thinking blown rectifier that I'll be asking other questions about as soon as I've made some voltage measurements).<br /><br />What I have now is a 1/2/Both/Off switch. One battery is a starting battery, the other is a gel cell. The boat sits in the water, unused for long periods of time, so the gel cell is to run the bilge pump. Currently, everything is hooked to the output of the switch, so I have to switch between Both for charging while running to 2 for accessories while fishing to 1 for starting and... see the problem? It is too easy to leave the switch in the wrong place, try to start from the depleted gel cell and have a dead battery that puts a big load on the charging system. Or to leave it on the starting battery, run the electronics and not have the juice to start easily.<br /><br />What I am thinking of doing is following the advice in the West Marine catalog -- they suggest using 3 on/off switches, one to connect 1 battery to the accessories, one to connect the other battery to the engine and the third as an emergency bridge to use the house battery for starting. In order to charge both, they recommend using a battery combiner device... something that works like a couple of diodes but without the voltage drop so that both batteries charge when the motor is running but don't drain one into the other if they have imballanced charge.<br /><br />What do people think of this setup? Does anyone see any problems with this (other than the expense of 3 new switches and a battery combiner)? Suggestions on how to accomplish the same thing for less money? <br /><br />Thanks for any thoughts.<br />mike
