Mark42
- Oct 8, 2003
- 9,334
I have a PC with a Biostar U8668 Grand mother board in it that supports 6 usb ports (three usb headers on board). The mb has two usb ports on back directly connected to the mb usb header, and two usb ports on the front connected to mb usb pin header with a narrow ribbon cable. There is a third USB pin header unused.<br /><br />The ports on the back support USB 2.0, but the ports on the front are only USB 1.0 I have downloaded and reinstalled the USb 2.0 controller and still only have 2.0 on the rear. I moved the ribbon cable to the unused usb header and it still is only 1.0.<br /><br />The rear ports are directly mounted on the motherboard usb header so trying to connect a ribbon cable to it is not an option.<br /><br />In Device Manager under Universal Serial Bus Controllers looks like this:<br /><br />+ Universal Serial Bus Controllers<br /> + USB Root Hub<br /> + USB Root Hub<br /> + USB Root Hub<br /> + USB Root Hub<br /> + VIA rev 5 or later USB Universal Host Controller<br /> + VIA rev 5 or later USB Universal Host Controller<br /> + VIA rev 5 or later USB Universal Host Controller<br /> + VIA USB 2.0 Enhanced host controller<br /><br />It has the Enhanced host controller that gives 2.0 support to rear ports on rear header. All drivers are the same across the host controllers and hubs. <br /><br />How do I get 2.o support to the other usb headers? This is driving me nuts.
