CalicoKid
- May 27, 2002
- 1,599
I recently purchased a Gamo Shadow 1000 pellet rifle for home pest control (residential neighborhood). It is a .177 cal 1000 fps break-barrel action. I have an air rifle scope with a recoil block mounted. It has a somewhat adjustable trigger pull.<br /><br />I've got it sighted in as close as I can but can only make a group of around five inches at a hundred feet. I believe it is due to the violent recoil of the piston jarring the gun before the pellet has left the muzzle. I remember the old pump up guns being extremely accurate, able to put one pellet behind another at a hundred feet. I would attribute this to the lack of recoil due to no moving spring and piston during firing.<br /><br />My question is: are there any muzzle weights or other apperatus out there for pellet gun recoil? My 10/22 has a mini maglight mount on the barrel, I might try that on the Gamo. Anyone here shoot air rifles?<br /><br />I've tried four different types of pellets and have settled on a Beeman coated hollow point and a Gamo match point. I've put around 500 rounds through it so far.
