daveswaves
Ensign
- Mar 22, 2002
- 901
Re: Same Jeep different problem
My experince with a Jeep Cherokee( 340,000 km) would lead me to check the tps voltage and make sure it is "smooth". Use an analog meter, not digital, and monitor the TPS output at the connector. Look for "dead spots", especially around the beginning of your throttle travel. Voltage swing is theoretically from 0 to 5V, in practice it will not be 0, probably around .6 V and will swing up to 4.7 V or so. There are three wires coming out of the TPS, can't remember the colors off hand but one pair will swing from 0 to 5 the other combination (using the center wire common to both) will swing from 5 to 0. One side "talks" to the Transmission control module and the other "talks" to the ECM.<br />With all the mail box starts and stops the TPS gets extra wear.
