Re: new 5ph 4stroke, gas in oil, what to do?
Jerry,<br /><br />First, it's really unlikely that there is a problem. As the series of above posts point out, their are a number of normal things that can cause the fuel to wind up in the oil. And there is no hard and fast rule about how much over what period of time would be normal. It's more a matter of it being obviously full of gas after some hours(meaning 10 hours) of running time. I have an idea that you are monitoring it a little too much. Here's what I would do...and it's what your local dealer will do if you take it in...Change the oil, run it...hard, for at least 5 hours without checking the oil. Then look at it and see if you have gained a lot or a little. If its a lot, then take it in to the local guy. I know that's not a great answer or a perfect solution, but that's the way we do it.
