Re: HELP! Salt water in my 130's
I do not know how fuel got into the tank yet, as I am going to fix the engines before I fix the tank. I do know I have a leak in the hull though. I have two front compartments, both with drain holes. After the incident, I put the boat back on the trailer, and gas was leaking from both drain holes, but there was no fluid in the compartments. So my guess is, I developmented a hole in tank, and I already had an existing way for salt water to get in the bildge(being forced up the drain holes, then through the foam while under way).<br /><br />Back to the engines, I need help understanding why a leak down test is in order. With the compression being as bad as it is, what else could be done to fix them without a teardown?<br /> Those posted numbers were taken twice, once right after the fuel system was completely gone over, then five days later after the chambers were completely filled with marvel mystery oil and left to soak. At the end of five days, the oil had drained completely out of the all the cylinders except starboard #4, the only one with decent compression. The compression numbers were exactly the same.<br /><br />To answer your questions, the engines were not submerged or anything like that, but were ran on what I figure was almost exclusively satl water till they just stopped.<br /><br />Thanks so much for your advice guys?
