Re: Honda B100 oil pressure?
That oil pressure light works off the voltage from the pulser coil , charge coil, sensor coil. All these names are for the same thing but from different manufactures.That coil sends voltage to your oil sender that is inconsistant.The magnets on your flywheel ,at idle,which create the field,that creates the voltage,too make this whole ignition system work,PULSE.That is why you will notice a flickering oil light at idle.What you are really looking to avoid is an oil light that fades at any time. Bright is right.
