hello i have a problem with my engine i think i have a 1985 bayliner capri it is a 16 ft boat with a 1987 force 50hp engine i purchaced the boat from a freind this year but have been using it with him many years before i purchaced it he had a problem with the lower end slipping so we changed the forward and reverse gears it did not fix the problem we then found that the center on the prop had been sliping so we changed it with another one that we had and it cured the problem but the pitch was wrong so the boat would only rev to 3500rpms and would not plane out(michigan 072132) so this year i purchaced the original prop from iboats (michigan 072131) and now it will launch fine out of the water but around 3500 rpms it will rev really high like it is cavatating, and this is the same size prop that was originally on the boat for many years and we never had this problem and now i am plum out of ideas on what could be causing this any info would be great thank you
