Re: backfires but runs great
Guys,<br /><br />I can't accept the idea that the carbs are designed to leak when you tilt the motor forward. The fuel that drips from the cowling is a huge health / safety issue and I don't se how the US government would have ever let that go, even in the late 80s.<br /><br />I just got my replacement needle valves and have not installed them yet but just cleaning the carbs and resetting the float levels has reduced the leak, reduced the backfire on startup and reduced the stalling when going into gear.<br /><br />I anticipate the new needle valves should make it even better.<br /><br />Maybe I'm just anal retentive but I don't see a reason why these engines can't be made to run correctly with some time, patience and a good understanding. Especially if we all stick together and share our knowledge.<br /><br />Jeff
