Re: force 125 trim/tilt
Hello Kaye!!!! Welcome to iboats......<br /><br />Self Bleeding....strange term....but pretty much describes how to bleed of the TNT unit. <br /><br />What it basically means is that when you cycle the engine up and down, any air in the TNT (Trim N' Tilt) system goes to the fluid reservoir. Removing the fill plug lets the excess air out.<br /><br />The procedure is....with the engine at full tilt up, remove the reservoir fill plug and top of the reservoir with TNT fluid. Cycle the engine up and down 4 to 5 times and with the engine in the full tilt position, remove the plug and check the level again. Should be even with the fill plug hole. Top off as needed and do another cycle. Do this until the level stays constant.<br /><br />Most any kind of TNT fluid will work. The best thing to do is contact a dealer and get his recommendation....(long word)...on what to use for your particular engine.<br /><br />Hope we helped a little....thanks!
