1985 19' Bayliner Capri w/ Force 125 o/b <br /><br />With a 21 pitch prop top speed is 30 and a slug to get to plane. Pulling tube top speed is 20.<br /><br />Switched to a 15 pitch prop after checking plugs, fuel filter. Took it to the lake to try it and was very pleased with the way it jumped up and plained out quickly, but top speed was 30-32.<br /><br />Will a 17 pitch give higher speed? I know I need to get a tach as to not over rev the motor.<br /><br />How fast should the boat go? <br />What is the best way to go as far as adding a tach?<br /><br />Any suggestions on my problems? Thank you for your help.
