Hello, <br /><br />I have bought a 1970 - 55hp outboard from chrysler. The engine is in good condition so it was a good deal, but I found a bug. The propeller is loose. It can be slightly moved on the interleaved drive shaft. The first thing I did was removing the propeller and looking what's up. The reason for that is that the propeller cannot be pressed on the interleaved drive shaft because there is a grooved pin through in the propeller. I thought there should only be a safty pin through the propeller and the drive shaft. <br />Can anybody help? The next thing I will do is removing the grooved and replacing it with a safty pin, which is thinner so the propeller can be slipped on the drive shaft so that it is fitting thight. <br />Sorry for my humble english, but I'm not a native speaker.<br /><br />Stefun
