hello, another problem for you. have 97 force 120. starts up no problem, seems to be stuck in foward. prop is spinning at a low rpm, wont go into nuetral or reverse. tried to shift it manually also, after i disconnected the cable, but it didnt work it has a spline shaft connection, and the only thing i did was lower unit to cange oil and impeller...any guesses?
