Re: Force 90HP - distance between piston and cylinder
WHM, thankx for your hints, but it's to late. I was unable to cancel the order of the mercury/quicksilver pistons. Today I got the oversized pistons 0.01". In the piston kit from Quicksilver is a boring instruction for oversized pistons. The instruction just refer to the finished hone bore size, which is 0.01" greater than the standard. So the hone bore size should be 3,385" for 0.01" oversized pistons. There is no information regarding the clearance, because the recommend finished hone bore size does take care of the necessary clearance. I agree with you that the Wiseco oversize piston is the better choice, due to good experience from other peoples. Do you have a suggestion (finished hone bore size) for me to improve my situation with the bought oversized pistons from merc ? I regret that I found to late this forum.
<br /><br />---------<br />berndie61 - the force rebuild beginner
