help! tahoe lost all power
keljas
20107400e tahoe 195 lost all power after running great for 2 hours. Pulled up to dock to drop off someone the backed out and put in idle. Just shut down. No power to the dash, ignition, horn. Only to blower. Replaced battery and the 50amp not tripped. Fuses look fine. Help!
Risslanae
We have a 2007 Tahoe Q7i and just had this problem tonight. Were you able to fix yours, and if so, what was the problem? We were out in pretty choppy water, so we were thinking that maybe a connection came loose, but couldn't find anything. Hope you can help!
keljas
There is a 15v fuse behind the motor...in a little black box straight back from the red reset button. Kind of hidden. It was blown. Easy fix. However it keeps popping anytime we put in reverse and if we dont put in neutral easy it will blow. It is a problem in the gear shifter...we havent taken it apart yet to see but must be pulling a wit of some sort. We had the complete boat taken apart and no issues anywhere else. Shift control only thing not taken apart at that time. Then found this lost fuse and bam! There was the fuse! Hope this helps.
