Ok, I have the transom in place and have marked where all the holes are. Should I go ahead and drill all the holes out while in place, or remove the transom and drill the holes that I have marked? Do I need to drill out from the inside of the boat out? Sorry for the dumb question I just don't want to mess this up. Thanks.
JD I gave you my suggestion in my last post, remove the wood and drill the holes straight through and then when you put the transom back in the drain tube holes will be at the correct angle.
1' diameter drain tubes.
http://www.iboats.com/Search/dm/?ke...it.y=0&*******=142104524&**********=597783718
If you want to go with the AL tubes you'll need to flange them with the tool. Also buy an extra tube just in case, they're cheap.
The drain tube holes should be drilled straight through the transom wood and when installed the holes will have the correct angle. What I've done is install the wood, sharpie mark the holes, remove the wood and drill the holes straight through.
I would go with the AL tube - http://www.iboats.com/Drain-Tube/dm/*******.578418828--**********.176685679--view_id.39188
Some have used the plastic one, but the flange on the AL tubes are thinner and fit inside the splashwell better in my opinion.
That is the size you need in the link 1" dia x 1-7/8" I hope you were the one who ordered these and made the low stock, right now it says only 1 left in stock here at iboats. I've only used the AL ones and flanged them with the tool I made.
Thanks for the input guys. Now worries about the tubes. I am sure I can find some shortly. I need to get this done so I might have to look on ebay.
I have the new transom in and the motor mounted back. I will take some pictures this evening and post. I still have the splash well out until I get everything re-wired.
