crankbait cowboy
- Mar 25, 2013
- 570
No Title
well i took some time and put lower unit on (pic 1) and had a buddy help, we got tubes in right place and lo and behold after snugging it got linkage hooked up and it shifts as supposed to. then i went ahead and put a tell tale in. drilled a 11/32 inch hole in cylinder wall and tapped with 1/2 inch and screwed in fitting ( pic 2) then drilled 1/2in hole in cowling and bored out with a drill and tapered grinder bit ( pic 3 ) then used 3/16 fuel hose to connect the 2 (pic 4). it went real well and gonna be nice to have for my spring test. by the way , the goof off worked great for removing decals on cowling with a scotch pad(pic5). plan now is to wait for spring, put on muffs and run and shift it hoping al works as planned, if so i may just run it and see what happens. thasnks for stopping by
