FIGMO
- Jun 18, 2017
- 320
Mr. Watermann,
I really didn't want to hear that (read that). Okay so Hienz vinegar spray to help remove the corrosion. Where do you get the Hienz? Can you provide an example of a soft wire wheel? What did you use to fill the pitted portions of the skin? If other posts are any indication, then I am guessing that JB Weld would be the solution for that.
If I am understanding you correctly, once you cleaned up the inside of your transom skin, you then painted the inside of the transom skin. Is there any special paint I should consider for that task?
I would really appreciate some details on the removal of the Z brace. I know you posted a link on another thread (which of course I can't find again) about rivet work. I will be honest, I have never riveted before. I did want some Youtube videos and it looks fairly straight forward, but its the closed/solid rivets that I am not 100% clear on.
Again, I appreciate your input Mr. Watermann I said to myself at the beginning of this project that if I was going to do it, then I was going to do it right. So I guess I will tackle the Z Brace once I have properly prepared myself for the task.
