Ketchum917
- Jun 20, 2007
- 2
Ok, this is an interesting one and probably a long shot at identifying the issue over a web site, but I will give it a shot. While on the lake this past weekend, my 2004 Lund Pro V recently filled with water enough to come up through the floor. We had been out in the boat all day prior to that (all weekend for that matter) and had no water problems. The boat was in the water, tied to the dock all weekend (didn't pull it out at night) with no issues. Livewells were running all weekend and had no issues. I bilged the water out, checked the drain plug and didn't have a problem the rest of the day. The boat was in the water overnight that evening and was dry the next morning.
I tested the livewells yesterday (in the driveway) and no issues, the overflow was draining just as it should. I had the boat tilted way up while filling the wells through the pumps so any water leaks should have run to the back and there did not appear to be any leaks in the hoses. Although the drain plug for the boat was tight when this happened, other than that leaking, I just can't imagine where the water could have come from. Unless the plug was loose and tightend up some from the water pressure by the time I checked it. Had it been a rivet problem or leak elsewhere it should have been a problem earlier during the weekend and certainly seems like it should have filled with water again right away.
Has anyone experienced anything like this or can you think of anything else that I haven't mentioned here that I need to check? I will take it to the dealer if I must, but I have no confidence in the dealer I bought it from and they will need the boat for about a month (as they always do for any repairs). I'm sure I can find another dealer, but just trying to rule out something simple that I am not thinking about.
