This is the first time that I have been on this site and I hope someone can help me out. I have a 2003 Caravelle 187. I took it out for a spring test run and it ran perfect for about 2 hours. After that, it just died in the water. I was not able to get it restarted for several days. I replaced the coil. I took it out again and it ran fine for 1 hour and then did the same thing as before. I have changed the coil, the fuel filter, and the oil. I was tolled that it could be the run/off switch on the throttle and drive control. I took out the switch and had it checked at the dealer and they said it was bad. Now I have a new one but don't remember what wire go's where. I have two solid purple wires coming from the boat wiring harness that the other switch was connected to and I have one solid black wire and one black wire with a yellow stripe coming from the switch. If anyone can help I would greatly appreciated. Thanks, Chris
