Interesting.......
Maybe a little less friction, but there is still friction points the balls have to touch yet...
Magnetic levitation comes to mind. Think bullet trains.Until they can suspend the balls in total space without touching any other balls or inter and outer races, they will always be friction... And presently we don't have the knowledge or technology to accomplish that ability. However, who knows what the future will and can bring... :noidea:
So if you reduce it by 1000%, does that mean the bearing actually rotates on its own?If you reduce the friction by 1000%, the efficiency of a drive will increase substantially.
Only on the Internet...lolSo if you reduce it by 1000%, does that mean the bearing actually rotates on its own?
Aluminum stuff.foodfisher, if magnetic levitation is used, there would be zero needs for a bearing then...
