- Mar 8, 2009
- 40,754
Bought a Camry for the grandson's first car. Installed new battery and checked the charging circuit and all doing good. Parked it and it sat for more then a week. Tried to start it and nothing, dash lights wouldn't even come ON. Battery was dead, so recharged and go it running.
The ALT would put out some times and not another, might be the meter connections or the meter. So pulled the ALT and took it to local shop, they checked it out and said there is nothing wrong. Reinstalled, started and its putting out good voltage.
With motor OFF, pulled the positive cable and checked for amps. Was seeing 60 mA or so drain. One by one I pulled every fuse, and relay and there was no change in the current reading.
Anyone know of an unused keep alive connection?
