bruce, thanks for the info. ThermalArc never came up on any of the top ten reviews I researched. But seeing its from Victor gives me more confidence than the Everlast. I may go that route when I'm ready to buy.
Howdy,
I may have missed it, but what kind of welding are you going to do?
That Thermal Arc unit is similar to my Miller Synchrowave 180 in power and operation. It appears to be similar in price too.
(The Synchrowave 180 was replaced by the Syn200) I wish I had held out for the 200.......For aluminum, I frequently run mine "flat-out"
I have never heard anything bad about Thermal Arc equipment either, If it was cheaper, I would get it.
Now having said that, a stick/GTAW welder might not be the best choice depending on what you're wanting to weld on a regular basis.
If I had it to do over again, I would get a Miller Autoset 211 (or something similar) because it will allow MUCH quicker all around steel/SS welding and for low amp jobs, you can run it on 120VAC. for higher power, you just connect it to 240AC
I do not do a lot of aluminium welding but the 211 works well with a spool gun.
If you're going to do a LOT of fab welding, or automotive sheet metal a wirefeed is much quicker and easier than GTAW. ( formerly known as TIG)
Bruce, My Harborfreight plasma cutter still works!!! (fingers crossed!!!)
Regards,
Rick
