gm280
- Jun 26, 2011
- 14,592
JASinIL2006, Glad you bought a MIG welder now. I think you will love welding, even while learning. It is addictive. But I also bet that well over 90% of the time you will never need the extra welding capabilities of the 220 volt unit. But at least you have that capability if needed. If I were you, I would either buy or make a very good extension cord for the 220 volt setup so you can take the welder to different places to weld things. Because some times you can't get the things you need to weld to the welder.That was one reason I went with a 120 volt MIG welder. Because the everyday welding that most of us do, is not always able to be moved to the welder. So make a good extension cord with large gauge wire to handle the current. You will not regret it. JMHO
