A problem for you mathmaticians!
Boomyal
Here is the deal, I need to order 4000 lbs, combined, of two different filter medias. I need to figure out how many 50 lb bags of each media I need to order to make up that total, in the proper ratio.
My current supplier has just raised it's price by 26%. I cannot pass this increase along to the customer nor can I absorb it. Whereas I have been buying the mixed media in 43 lb buckets, I may be able to get them cheaper, by the pallet, in 50 lb bags.
When I have been purchasing it in the 43 lb bucket the separate layered medias (I mix them up in an electric cement mixer for administration) each weigh the following: Media A weighs 35 lbs. Media B weighs 7 lbs.
How many bags of each media do I need to order to make up a 4000 lb load?
fhhuber
4000 / 50 = 400 / 5 = 80 total 50 lb bags.
35 (A) + 7 (B) = 42
80/42 = 1.9047
1.9047 * 35 = 66.6666.......
67 bags of A
14 bags of B
You'll have some left over of each.
MTboatguy
God, I feel like I am back in High School and I didn't do very good at that!
:eek:
:lol:
fhhuber
I took this:
To be the ratio... since it was the only ratio in the OP.
sam am I
In words?........
Each batch = 42lbs............35lbs of part A and 7lbs part B = 42lbs
Wanted 4000lbs of mix
4000lbs at 42lbs per batch = 4000/42 = 95.24 batches can be made with 4000lbs of mix
95.25 batches of part A requires 95.25 * 35 lbs = 3333lbs of A
95.25 batches of part B requires 95.25 * 7lbs = 666lbs of B
3333lbs of A in 50lbs bags = 3333lbs/50lbs = 66.66 (67) 50lbs bags of A
666lbs of B in 50lbs bags = 666lbs/50lbs = 13.32 (14) 50lbs bags of B
What is the ratio that you mix it at?
mix ratio appears to be 35 parts A divided by 7 parts B, 35/7 = 5 parts A to 1 part B or 5:1 by weight
gm280
sam am I hit it correct. Since there are a total of 6 parts (5:1), divide 4000 by 6 and you arrive at what each part would be. And then multiple that times each part in the mixing ratio and you have it.
Boomyal
Excellent all. Thanks for the calculations and the explanations!
Boomyal
I wanted to verify this calculation but something is not adding up and I cannot see where. I changed the numbers a little bit but followed all from above. Here is what I did.
4000 lbs total. 36 lbs part A and 7 lbs part B = 43 lbs of half cubic foot load.
4000 lbs / 43 lbs = 93 batches
93 batches of A @ 36 lbs = 3348 lbs
93 batches of B @ 7 lbs = 651 lbs
3348 + 651 = 4000 lbs (round numbers)
SO FAR, SO GOOD, BUT NOW I HAVE TO TRANSLATE THIS INTO THE APPROPRIATE NUMBER 50 LB BAGS, OF EACH PART, TO MAKE UP THE 4000 LB ORDER. THIS WHERE IT BREAKS DOWN
3348 lbs of Part A / 50 lb = 67 bags
651 lbs of Part B / 50 lb = 13 bags
13 + 67 = 70 50 lb bags
When I multiply 70 bags by 50 lbs I only come up with 3500 lbs total, not the 4000 lbs that they added up to above. :help:
Boomyal
How much is 13+70? LOL
Whoops!! I really blew it. :facepalm: I thought it would be something simple, but not something stupid! :noidea:
I knew there had to be 80 50 lb bags to make up 4k lbs, I just couldn't get my calculations to arrive at that.
gm280
Ha when in doubt, fake it. Always works for me.
NYBo
:eek:
:lol:
My math teacher used mixtures of different types of candy for such problems. Using filter media instead would probably have resulted in even more blank stares than the candy did!
