Boomyal
- Aug 16, 2003
- 12,072
I bought myself an 18 oz can of R134 at Wally World for $23, It came with a gauge and hose. This morning I went out and started the 2006 Explorer up and turned the air on to it lowest temperature setting. I also turned the fan on high. The outside temperature was 76?.
I immediately noticed that the compressor was cycling on and off every few seconds. I thought that to be odd. I hooked the pressure gauge up to the low pressure port and every time the compressor cycled the pressure would go from about 15 lbs (off) to 55 lbs (on) It did this repeatedly. I left the gauge hooked up and turned off the A/C. The pressure went up in the red to about 100 lbs. I did not leave the gauge on long to see if that pressure dissapated.
What could be going on? There should have been no reason for the compressor to be recycling every few seconds. I had the doors open and the temperature set at 60?. I have only owned the vehicle for 1 1/2 years and have no way of knowing if it had ever been charged before. Also when the compressor cycled on the gauge would go up to 55, sometimes 58? (still in the green range) which was higher than the chart said it should for the ambient temperature.
