Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
what are you guys skiing behind?
  • what are you guys skiing behind?
    Looking to get back into water skiing after 10 years off. Looking at boats and there is a nice Ski Nautique I would love to look at, however Iam the only one that currently skis and we live in NJ and the bay isnt the nicest place to crusie with a lake boat...I was looking at I/O's...just wondering if I am going to be real upset with the wake those things kick up...I skied for 10 years behind a Toyota Epic..300 HP ski boat...was nice in that it was boyrider......thoughts?
    Skied primarily behind a 2005 bayliner 195 for 9 years, now I ski behind a 2012 Malibu VTX and a 2004 Malibu Response LXI (occasionally). The Response is the nicest to ski behind and the least versatile boat of the bunch - worst boat in chop. The Bayliner was underpowered but decent enough to ski behind. My VTX is decent to ski behind (15 off) and the most versatile boat of the bunch.
    2012 Malibu VTX 5.7 Monsoon 350
    2009 Ram CC 5.7 Hemi
    www.oldjeep.com
    • #3
      Thanks....Im the only one that skis soe its hard to get a boat dedicated to skiing, but I really want to salom
      • #4
        Might be worth finding some skiers in your area and making a deal fuel for ski rides.
        www.oldjeep.com
        • #5
          There is no need for a ski specific boat unless that's all you do. Mine has plenty of power for multiple skiers or tubers. Only thing missing is if you're serious into wakeboard stuff and want a boat that throws a big wake. And wakeboard towers can be mounted to many types of boats.
          I ski behind this...
          2007 Glastron GT205
          5.0 Mercruiser
          • #6
            You can slalom behind a lot of boats provided they have the power or can be re-propped to get the power you need. The problem comes in when you are wanting to make hard cuts from one side of the boat to the other. That's when the wake can beat you to death if its too big. Bowriders typically have pretty big wakes. Nothing too big that it would be an issue for just plain skiing. But, if you are going to ski hard, make big cuts, a bowrider isn't your answer. Ski specific boats are great and some come with open bows. That might be a compromise but you will still have the engine mounted right in the middle of the boat. Take your time to make your decision as I bought a bowrider, made lots of improvements then discovered that the wakes were too big to do what I needed to do. Good luck with your search!
            2007 Tahoe Q6, Mercruiser 4.3L MPI
            • #7
              I am skiing behind a '97 Crownline 182 with a 5.7L. It is plenty stern heavy, especially as we get loaded down with passengers and gear. It has plenty of grunt to pull me out of the water on a slalom ski (5'11", 215lbs and 57 years young right now). Got up behind it Saturday with four adults in the boat, and me in the water. It took a few pulls to get my technique back, but was able to get it done.
              I agree with the comments here tho... the bowrider puts up some wake, and when in mid season form, crossing the wake at high speed with lots of carve can be dicey, especially if the lake has any chop at all. The crownline has been a AWESOME first boat for us (first that I owned anyway). It does a lot of things very well, but it probably is not the BEST slalom boat, nor can I surf behind it, which is something I would like to do more of as I get older.
              I have started looking around at some inboards, but nothing has taken me away yet, plus Im not sure I am ready to part with the Crownie YET.
              1997 Crownline 182 BR
              5.7L Mercruiser Alpha 1
              • #8
                "Ski boat" means different things to different people.
                Enough power to deep water start the heaviest slalom skier, with eight adults in the boat?
                Ski around the lake riding straight behind the boat?
                Enough space, storage and a head so you can be on the water all day with ladies on board and accommodate small bladders?
                You like to jump the wake so bigger is better?
                You boat on a huge windy lake fighting with other boats throwing large waves, so a smooth riding deepest V-hull is priority?
                Any boat is a compromise, so you just need to prioritize. I ski on a small lake, early a.m. with one or two friends. We don't need to haul people, the water is flat or we don't ski. I share a 12 yr old Malibu LXi. (Open bow, 340hp 5.7L) with an aftermarket exhaust that makes it one of the quietest boats on the lake so as not to annoy neighbors. And we ski 34 mph short line, sometimes in the slalom course. I'm spoiled, a bit of a snob even as I dislike a lot of other ski boats if there is too much spray or a funky wake dip at 35' off.
                At the same time I pretty much love all things skiing and have skied behind about any kind of boat out there. I'm just an advocate of skiing with whatever you've got to work with.
                That said, if you get to choose, I'd avoid I/Os of about any kind, in preference for an outboard powered rig. About 600 lbs less weight in the back of the boat means better hole shot, and smaller wakes once planing. Lower deadride (less V) in the hull helps too, so bass-boat based fish and skis ski pretty darn well. Otherwise I would choose a 18' bow rider with 150 outboard over same hull with a v6 or v8 I/O. Similar hole shot and always a better wake.
                Assuming you like to slalom back and forth through the smallest wake possible, that gets my vote.
                If you are skiing fast enough (my opinion, on the high side of 30 mph) so a direct drive's wake flattens out. If the weird interior layout works for you, and you can put up with rough ride on a windy day, a direct drive in SOME years and models can be a beautiful thing.
                • #9
                  All of the above is excellent advice. I slalom occasionally behind a Crownline 180 BR. But the wake that boat throws is brutal. Luckily, I wakeboard too, and it's perfect for that. Like skibrain says above, if you are a slalom skier, I would stay away from I/O's, unless you consider installing some trim tabs, which help the boat get on plane easier and can also reshape your wake to a certain degree. However, if water sports are a priority, I'd skip the idea of any kind of I/O and O/B setups, and go straight for the inboards. Mastercraft's, Malibu's, Moomba's etc. Any one of those boats will cruise well, and yank the rope right out of your hand. I miss slalom skiing behind a small wake.
                  However, if you're dealing with large waves, an I/O may be the best option. If you do have to go that route, make sure you get the biggest engine/HP you can get in the boat. It will pay off when you're not dragging behind the boat underwater for 60 yards until the boat planes out.
                  • #10
                    Skibrain, I would so love to have a morning of skiing like that. I am still very much in a world of compromise, both with my boat, and with the lake I ski on. Dont get me wrong, I still grin ear to ear every time I get up on the slalom, and I will take what I can get. Having said that, my best days are with three people (I have to have a driver AND an observer here) that are dedicated enough to get out early. But most days skiing is taking the family out as early as I can get them moving (read that not very early, get to the lake by 8), take a couple pulls then duck into a cove to escape the rough water for the rest of the day.
                    Less than ideal, but I am SOOOOO glad to have bought this boat in late 2014. Ive managed to get a lot of skiing in, and our family LOVES the boat.
                    • #11
                      I'm an outboard fan as well. Our boat is a deep v so the wakes are a interesting on slalom and I was yelling at my boat last night (ha ha). I want to upgrade a V-drive someday but don't want a boat payment so I have to live with the wakes I have for now. I also like the idea of some of the Hurricane deckboats out there with a 150 outboard (seems to have a slallower V). We always have 5-7 people on the boat.
                      here is my boat:
                      Click image for larger version
                      2003 Malibu Sunsetter LXI, Acme 525, Radar P6 ski
                      (I still like to help with Force outboards !)
                      • #12
                        Just because I have access to a direct drive ski boat now, my history ranges from probably the smallest wake ever behind a 13' Boston Whaler soon perfect for pulling kids, but it was too light by the time I got to be 16 yrs old:
                        To my first boat, a 15' Glastron with 90 hp. $2,500 It fit in my garage and could pull behind my minivan. Fast enough to barefoot behind, so all is good. The boat would look smaller except my sons were really young in that '98 photo:
                        A 16' CVX with a 120 hp. Deep V hull, but the boat WITH motor (1,100 lbs) was so light that it had a very small narrow wake.
                        • #13
                          Decent shot of the wake behind my BIL's Glastron GX180 outboard. pretty darn small for a bowrider. And not bad hole shot pulling up 8 skiers (4 adult size, and 4 younger) but we were running a 150 outboard with 21" pitch prop. The boat will run nearly 60 mph GPS with a light load!
                          And the LXi
                          • #14
                            that is a really nice wake behind that GX180 ! - i would love that.
                            • #15
                              milehighjc I worked hard to recruit the initial 2-3 friends that would get up and ski at 6:30 am. The rest of my ski network I've met at the lake - like minded folks who are already making the decision to be out early. Now people are calling ME to go skiing.
                              Yes there were years with my kids and their friends packed in a small boat on a busier lake, but I didn't bring my own skiing expectations to that.
                              It's all good!
