Re: Sound system for wakeboard boat
not hard, but a lot easier to do during construction of the tower than after.
We took the tower off the boat to wire it. Drilled two holes - one each near where the speakers would be mounted, and a 3rd hole down near the mounting plates where the wires coming from the amp would enter.
At that point we routed the two sets of 12 awg wire using a fish tape. It was a bit tedious, but not too terribly time consuming. Definitely helps to work in pairs so one can keep an eye on the exit hole giving guidance to the fish tape operator.
On the "in" side we found an 8 wire connector that we installed to allow for quick wire disconnection when the tower is removed.
We installed grommets on all 3 holes and made all our terminal connections with solder and heat shrink. We're running a pair of 8" bazooka tubbies and a bridged 4 ch amp around 150w rms x 2. We also installed some docking lights and ran wires for those as well.
It has all worked well for several yrs.
