Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
DIY pro wake vs krypt pro air towers
  • DIY pro wake vs krypt pro air towers
    These two towers seem very similar, but the krypt is $100 more. The krypt is 2.25" tubing v 2" tubing on the DIY. Is the extra size in the tubing worth the $100? Also neither of these towers seem all that easy to take down. I garage my boat so I would prefer a tower that folds easy. Any opinions on these?
    http://www.diywake.com/shop/shopexd.asp?id=616
    http://www.bulletlines.com/wakeboard...ower-p/250.htm
    Re: DIY pro wake vs krypt pro air towers
    good luck, if you havent noticed everyone around here seems to think diy wake is the cats meow. hard to get a good opinion on the other brands
    • #3
      Check the Krypt towers on ebay. They have been selling pretty regularly from $450 to about $750 with about $150 shipping.
      Look like a good tower. if I can still get a good deal in the spring I will be getting a Krypt myself.
      2008 82' Sunseeker Predator...... Gotta hit the Lotto.
      • #4
        Been very satisfied with my DIY wake tower (Pro swoop). I hesitated briefly on the thinner legs at the time. But now that I own it, I do not see how 2.25" legs would be better than 2.0" legs for this purpose. My 2.0" tower is absolutely stiff as a board, dead quiet, and doesn't flex or creak one bit. And we're pretty tough on it at times.
        I do not need to fold mine to get it in my garage, and I hope I never need to. It isn't horrible, but it's far from a "pull the pin and drop it" type of routine. You need a hex wrench, undo two bolts and loosen four more. When I put mine together I put it together TIGHT. I wouldn't think that repeated loosening and unbolting would promote a tight/quiet tower over time. And many of these bolts are threaded into aluminum. I'd think that eventually repeated usage will hog the threads out of the aluminum blocks.
        But I am just theorizing, so honestly I could be wrong on my predictions above. My DIY Wake tower is reportedly foldable, but I've never folded it...and hopefully I never will need to.
        • #5
          I've got the DIY on mine and garage it every time I take it out, (about 20 times a summer). Comes down in less than 3min. Easy. I did buy the hand knobs from Krypt for the front tubes so I don't have to use the allen wrench. I stipped out the pegs on one side using the bolt. Will probalby get another set for the top bolts so I don't have to use any wrenches.
          2006 Tige 20v
          • #6
            Got some pics?
            • #7
              http://i417.photobucket.com/albums/p...t/IMG_0097.jpg
              http://i417.photobucket.com/albums/p...t/IMG_0096.jpg
              2006 Tige 20v
              • #8
                This winter I'm going to put a New Dimension tower on my Nautique...custom built for it...Lil more expensive but beautiful tower and folds forward so can still work on the mid engine with the tower down...well worth the extra I feel.
                Good luck
                Derek "Doogie" Pfeiffer
                08 Larson 228 LXI 5.7L Bravo III
                93 Ski Nautique 5.8L
                07 Dodge 2500 5.9L Cummins
                sigpic
                • #9
                  well to tell you the truth i just went with a monster tower solid as a rock
                  • #10
                    This is the the tower I'm going with http://www.newdimensiontowers.com/ga...-1996_Ski.html
                    sigpic
                    • #11
                      I have the same DIY tower you have the link for. I dont see any differance in the two. The larger tube size wont make any differance in strangth only a few lbs of weight. The DIY tower folds pretty easy. The idea of adding the hand knobs in place of the bolts would make it that much easyer. Plus not only is it $100 cheaper, shipping is free also. Mine should up 4 days after ordering and was pretty easy to build. An extra person will be needed though.
                      Good luck
                      1987 Four Winns 215 Sundowner...
                      She may be old...but she's got it were it counts!
                      My refit/re-power project
                      http://forums.iboats.com/showthread....13#post2466813
                      3.7L rebuild: the thread
                      http://forums.iboats.com/showthread....13#post2578113
                      3.7L/470 altinator set up for about $100 with little modification needed and simple tooles.
                      http://forums.iboats.com/showthread....=1#post2892577
                      Back to Top
