OK, I was having trouble with IBoats and my laptop in the shop not getting along yesterday. Why the double post. In the house now and let me add more. SKF Speedi Sleeves have nothing to do with any BB product whatsoever. Total different animal. On where you deliver go ahead and ask as the manager as should know about them. Not the kid at the counter. It such a easy fix (must be done right though) and very simple. And when I said "Sillycone" for lube and seal, should have said RTV. And I would not call this "just another band aid" as people do worn out seal area on crankshafts. Let me find some more on it.Heres some..
"It's not that hard to do a speedi sleeve on a crank if you take your time and be patient with it. I've done several on industrial equipment and the only times I had problems was when I rushed the job.
First, be sure the crank is clean. I mean clean. Did I mention it needs to be clean? Then I applied a slow setting RTV to the clean crank to act as a lubricant and sealer. Now comes the gut check, applying the sleeve. Very easy, and using just enough force to drive it on, hit the setting tool in the center and slowly drive the sleeve home. I mean in the center... Did I mention it has to be in the CENTER! If you hit it off-center it could damage the sleeve and ruin the job. DO NOT HIT IT OFF-CENTER. Once the sleeve is home it is a good practice to remove the flange. If you have access to a pipe of the appropriate ID and it can be cut perfectly square, I would recommend using that instead of the setting tool that is supplied with the sleeve.
You can file a relief on the crank to help get it started, but don't be too aggressive.
Remember, start out perfectly clean, take your time, and drive it exactly in the center and you will be just fine."
From me. These are very thin, so proper install is needed. On a trailer axle, you can leave the install lip on. And thats it. Rest is replace seals, bearings if not perfect shape, Pack'em, hub on. BB on with just enough pressure to push the cup out a bit.and good to go. DO NOT over pump it, as thats NOT how bearing buddies work.
