dingbat
- Nov 20, 2001
- 15,501
Loadrite Trailer - #4800, tandem axle
Boat weight - ~#4300
Trailer weight - ~#1150
Tongue weight - ~#480
Rebuilt the trailer in the Spring. When changing the springs, I noticed that the trailer had 4 leaf springs in the front and 3 leaf springs in the rear. I called a local trailer dealer to inquire about my findings. He had never heard of such a thing and suggested that I put springs of equal weight back on.
I installed new 3 leaf springs, spring bushing and equalizer bushings. Lowered trailer to the ground and the equalizer all but bottomed out on the frame. I took it for a run around the block with no change in the position of the equalizer.
I went boating the following weekend. The trailer pulled well, but equalizer still out of position after a 50 mile drive. I dropped the boat in the water and the equalizer returned to its normal “equal” position. Thought all was well. We loaded boat back on trailer and same thing. Front equalizer almost bottomed out on the frame.
All indications point to the CG of the boat being too far forward on the trailer. The tongue weight is roughly 11% so I thought about moving the axles forward. Rough calculations for a 7.5% tongue weight (mfg. recommendation) has the axles moving roughly 13” forward. I may be able to move them 11” if I push the axle all the way to the forward cradle cross member, but then the boat would overhang the rear axle by almost 8 feet.
I’m beginning to think the trailer is too short for the boat and the PO made up for it with the heavier springs. I either get a new trailer or put 4 leaf springs back on the front.
