I have a trailer that a glass boat was sitting on and would like to use it for my 14' V-hull aluminum. The trailer had some type of fixed brackets for the bunk mounts and will not work for the tin boat. The width of the square tube frame is the right width to just bolt 2X4's or 2X6's flat directly to the frame. These bunks will be about 5' long and mounted to support the back of the boat. I will probably add a cross member with a roller to support the front of the boat. Can anyone think of any issues that may crop up with the trailer set up this way?
