Hello everyone I have a 1988 24 ft Tracker Party Barge that sits on a Tracker trailer made for a 22-24 ft boat. My pontoons hang off roughly 2 ft off the end of the trailer. This is the original trailer purchased with the boat. I am about to completely redo the trailer and I am wanting to upgrade from the 10 inch fat wide tires to some real 15 inch heavy duty trailer tires. I basically have purchased everything to convert from single 2500 axle to tandem axle 2500 lb axles and add electric brakes. I know this is way overkill but I pull the boat 4 hours up and down mountains and we like to load up the pontoon with all our gear. So here is my issues #1 right now as the boat sits on the trailer with the 10 inches tires I have to backup my Tahoe until the muffler is in the water to get the boat off the trailer. If I add the bigger tires I am going to have to go even deeper so I thought of extending the tongue about 2 feet which should help with having to backup so deep. Unfortunately all the ramps at the lake are not very steep which seems to be the main issue. The boat is basically sitting perfectly balanced on the trailer and there is almost zero tongue weight. In fact when I tow it I have to move cargo to the front to give it some weight so it want sway. I guess the main issue is if I add 2 ft to the tongue is it going to mess up the center of gravity? I originally thought of putting the center shackle right were the original axle was located but with the added tongue length is this going to throw off the center of gravity? Do you think I am completely nuts for adding tandem 15 in tires for a pontoon boat? The reason I want to go so big is one time we had the boat overloaded and had 3 flats coming home and only 2 spares and don't want to ever have that happen again. If you can think of any problems or anything I am missing please let me know.
