Jerry_NJ
- Aug 23, 2010
- 250
This is an update of a 1 year old thread I finally took action on. But I till have some questions - I can include a picture but think it doesn't provide anything I can't handle in worlds.
Old thread is:
http://forums.iboats.com/forum/gene...-towing/644422-draw-bar-and-receiver-pin-size
Today I took a step drill, the largest I have, to enlarge the 1/2" locking pin hole in the drawbar to 7/8" so I could lock my new higher up-step drawbar.
First, I was surprised how quickly and easily the step drill enlarged the hole. It took no more than a couple of minutes per side to enlarge the hole.
Second, now I wonder how much the modification compromises the strength of the tow connection. This modification moves the draw bar outward a bit over one inch (I can measure but distance is the standard spacing on drawbar receivers), leaving about 2 1/2" inside/behind the lock pin hole.. The drawbar has the usual loose fit, i.e., one can wiggle the drawbar a slight amount.
I think (can check) that my 2" drawbar arrangement is designed for trailers up to a couple of tons and for a tongue weight of up to 200 pounds, maybe more. My application is foe a 15" aluminum boar with a 9,.9 HP engine. I'll estimate the trailer at well under 1,000 pounds and the trailer tongue weight is under 100 pounds.
Does anyone have experience or ideas on the risk of a breakaway that may exist for the modification? This modification was discussed in the above referenced thread, and no one there expressed a concern about strength of the modification. Not trying to pass the responsibility off to anyone, but if anyone has experience or concern I'd appreciate reading it.
Thanks,
Old thread is:
Thanks,
