52Alumacraft
- Jul 26, 2007
- 29
I'm doing a little routine maintenance so I thought it would be good to re-pack the bearings. When I pulled the right hub off I found the spindle gouged up in the curved area where the inner bearing sits. Hopefully you can see the pictures. Is the spindle ruined or can it be saved? The surface the seal runs on is pretty rough too but I am not as worried about it.
This is a 3500Lb Shorelander trailer SLR2314SW. I put a Kodiak brake kit on it 3 years ago and it has made 3 runs to Canada at 1500 miles each plus a few short trips around home so maybe 5000 miles all together.
Appreciate any comments you might have.
