Re: Where to get rear grease seal for hub with BB's?
No advantage to running speedi sleaves to running on the original axle unless the original axle is pitted because of water.
I disagree Bruce, IMO there's nothing better than running a seal on a perfectly smooth non corrosive stainless steel sleeve.
Down here we go for the stationary seals so the stainless steel insert is a given.
SKF Speedi-Sleeve
Over time I've come to the belief with BBs that if your seals aren't weeping then your hubs aren't full.
Shock horror? No fully expected but I'm talking about a tiny bead of grease say 1.0mm that can be wiped off from time to time.
Another thing I do is pump the BBs up until just before the spring starts to bind rather than just until the piston starts to move.
Each to their own I guess but I'd take a lot of convincing to change from what I know works.
