Re: Adding Trailer Wobble Roller Assembly - Size?
I am not saying those won't work, but they will be a lot of trouble to adapt to your trailer.
REASON: The cross member is bent to a certain specified angle and pivots on the frame of the trailer. When you load the boat, the existing keel rollers push down on the center of the cross member and this raises the outer chine rollers into contact with the hull. The steel members that carry the chine rollers are designed to a specific angle both to match the bend in the cross member and to rise to the correct height. Without some trailer frame modifications or adding another bent cross member and roller assembly, adding extra keel rollers as I demonstrated in the photos is probably the only option with this type trailer.
BTW: The cross member has two sets of holes in each end and the frame pivot also has two sets of holes. By varying the position of the cross member in the holes, you can adjust both its height and therefore the boat's height above the trailer frame (and axle)
