seanymph85
- Nov 5, 2013
- 199
I am preparing to have 2 - 1/2' holes drilled into the end of my new trailer tongue to bolt it to the cross member on the frame. I need to know if the end of the tongue (2" x 2"x 96" steel tube) should be against the inside edge of the cross member when the 1/2" bolt is inserted through the top and bottom holes on the end of the tongue?
The old tongue only had a 3/8" or perhaps a little under that of metal tube past end of the hole to the end of the tongue. However, there is actually 5/8" of metal past 1/2" hole on the inside of the cross member.
So I am wondering if it would be better to try and locate the new 1/2" holes in the end of the new tongue so the end of the tongue is against the inside of the cross member (which will be harder to get precisely) or locate the 1/2" holes in the new tongue say 1/32 -1/16th under the 5/8" from the end to insure the 1/2" holes in both tongue and cross member will line up properly as well as still leaving more steel past end of 1/2" hole than on the old tongue.
Either way it would end up having more steel past the end of the 1/2" hole where it bolts into the cross member than it has on the old tongue.
Thanks for your input on this concern! If my description is unclear I can try to take some pictures to provide a better illustration of my concerns in locating the 1/2" holes in the end of the new tongue. FYI there is also a u-bolt that bolts the tongue to the frame near the area the 1/2" bolt goes through the end of the tongue and cross member on the trailer
