Re: Can I replace my tongue on the trailer without lifting the boat?
OK, to remove boat from trailer, tie transom to a tree or power pole, place a tire or two under transom and slowly pull boat off the trailer, tires catch transom...motor tilted up as far as possible. Use a gas axe (torch) to remove tongue (if it is in fact rotten due to surface oxidation)...measure thickness of rust, thickness of rust is aprox 7 times thickness of metal actually lost. When replacing tongue, take a center punch, mark hitch at center of trailer ball location. Remove tires/rims and measure from hitch center to a point on the hub, get exact distance from hitch to each hub...important to pick a point on each hub when taking measurements. Weld solid...this is the connection between tow rig and your most important reason for living...HA HA but seriously take your time and get it right, or replace tires before they ever dry rot...Hope this helps.
