Blahhhster
- Feb 27, 2014
- 11
http://forums.iboats.com/trailers-towing/before-i-order-bearing-buddies-617838.html
The link referenced above is some very helpful information. I have the exact trailer with the same dilemma. The unfortunate thing is I have been told several different alternatives, and I'm not sure what is the correct thing to do is.
1. Do I leave the existing easy lube system (which is supposed to be better)
2. Or, do I put on bearing buddies
My understanding is that the easy lube system pushes the grease behind into the outer bearings. If I remove the nipple from the easy lube system, how is the grease supposed to makes it way to the outer bearings. This just does not seem to make sense. There is not enough pressure with the bearing buddies to push through the small hole where the nipple was. The other aspect is that the easy lube system allows a lot of water in, and the Bearing buddies don't. Is this that critical?? Anyway, I think I already know my answer, I am just looking for some support!
I always thought the bearing buddies were the way to go, but in this case I guess not. I am looking forward to hearing what you think.
