sphelps
- Nov 16, 2011
- 11,506
Hi everyone ! I know it's been discussed many times before but I am trying my hand at building my own guides .
I have decided on guides instead of bunks because my hull is painted and am afraid of bunks rubbing the paint off.
List of what purchased so far..
1 - 2" x 10' pvc pipe
1 - 1.5" x 10'
2 - 1.5" end caps
2 - 1.5 repair couplings. The one with no ridge in the center .
2 - Large diameter pool noodles
I will be getting more stuff later to mount them to the trailer .
Ok so I cut the 1.5 " pipe in half and I cut the 2" pipe 2 pieces 2 ft long . I also cut the pool noodles in 2 ft pieces .
I then split the noodles in half and then slit the inside radius in 3 places .
I used spray adhesive to glue the noodles to the 2" pipe . then wrapped them up tight with some poly tape to dry .
I glued an end cap to both pieces of the 1.5" pipe. I slid the 2" noodle covered pipe on the 1.5" pipe then glued the repair coupling under the 2" pipe with about a 1/4 " gap . Take care to not put too much glue on the coupling so it does not puddle up on top of it . Wipe off any extra glue . Now the 2" noodle covered pipe will spin freely on top of the coupling .
With the way my boat sits on the trailer I should be able to mount it tight to the side rail and it work out ok .
Next I am going to get some white marine vinyl and sew a sleeve to install over the noodles .
I may ,for extra strength , slip a piece of 1.25 " pvc into the 1.5" to beef it up a bit .
Not sure how it's gunna turn out but I am hoping for the best . If it's a huge failure then oh well at least it didn't cost very much.. :joyous:
To be continued ...
1 - 1.5" x 10'
2 - 1.5" end caps
To be continued ...
