gm280
- Jun 26, 2011
- 14,593
Re: Bringing a trailer back to life
Ick, That is true. With the chrome rims I bought for this trailer rebuild job, there is a small ridge around the center of the rim that could hold water. Not too big though, but I am making a wheel cover for it so that isn't an issue with my setup. But you are correct, on some flat spare setups you really have to watch for that problem. Being covered and chromed (and waxed nicely too) I don't see an issue. I did the same on one of my previous boats and never had one issue with rust... Thanks for pointing that out so others will know of that possible problem... That IS what these forums are all about, to inform others! Also, with a spare tire cover, it keeps the UV sun rays from accelerating the dry rotting problems too, so you get a little long tire life. :joyous:
I have read about some spare tires mounted flat like you've done is that they can hold water and rust out the rim.
