TampaBoater
- Feb 23, 2012
- 207
I now love the rug covered / wood bungs on my trailer. Originally, I hated my boat trailer's factory design. Always cursed it on windy and fast current flow days. And, I would triple curse it under both these environmental conditions. But after I installed boat guides (not PVC "feeler" posts) on the rear of my trailer, all now works great. For my custom DIY board guides, I created / installed vertical steel posts, slid a hollow pool noodle over the pipe (for non-marking bounce protection), then set their clearance distance. Very low cost (re: cost $2 for pool noodles) and it's much stronger than store bought guide products. Now, I simply drive the boat between the vertical posts, gently bounce off these posts (like a ball inside a pin-ball machine - LOL!) and its front becomes centered. I then connect its bow hook and winch up the last few 8-12" (to the center support post). Or, I might simply "power load" until its centre post touches. Clean, simple and easy.
If possible, install steel vertical posts (with padding) on the rear of your boat trailer. Give it and try and it might work for you as well…
Since I've only ever owned a bunk-style trailer I don't know what I'm missing with rollers. I have seen a few boats with indents on the hull at the roller contact points, but I'm guessing that's probably from poor maintenance/adjustment on the trailer.
Reply's will be all over the place on this topic.
I've had both..Like both for various reasons already stated. I've modified my current bunk trailer in a way that works for me.
I added 2 additional bunks (4 main total), with 2 short ones up toward the bow to help center. The main bunks have "bunk slicks" nylon covers that make retrieval and launching a breeze. I also used side 4' bunk-guide on's. Not the poles, but the horizontal carpeted guides on each side than run before and after the axle. Never have any issues with centering. I even launch/retrieve off gravel beaches where there is no ramp with a 21'.
I've also lowered the entire profile to be lower. The Bunks themselves are as low as they can be mounted on the trailer frame with enough clearance. Then I mounted the springs below the axle. I have just enough clearance and have never hit the boat on the axle.
There isnt many ramps I cant get into, or out of. When retrieving, I only have to crank up the last 3-4 feet.
