Hi,
I recently upgraded my trailer lights to LED lights. After doing so and checking everything, the lights did not work properly. I found out my new Ford does not work with the conventional 12v system. It uses Pulse Width Modulation (PWM) instead. LED lights and PWM do not seem to work well together.
My car dealership has a TSB on this issue and basically they install a towing module and bypass the (BCM) body control module. By bypassing the BCM, you lose some hi-tech features; one of them is trailer sway control. I don't want to bypass the BCM.
My question is, can I add a load resistor in-line with the trailer wiring? A load to simulate the incandescent bulbs.
Has anyone had experience with such a modification?
